6509 Sup720 PFC 3B question
Feb 29th, 2008
My question is, i am applying service policy on vlan interface for output, it gives me this error.
priority command is not supported in output direction for this interface
Configuration failed
Here is the configuration i am using
class-map match-any Signal
match access-group 103
class-map match-any Voice
match protocol rtp audio
policy-map ProtectVoice
class Voice
set ip dscp 46
priority percent 70
class Signal
bandwidth percent 5
set ip dscp 24
IOS Version - 12.2(18)SXF11
Please let me know if anyone has gone through this and if any resolution.
Edison Ortiz Fri, 02/29/2008 - 21:18
  • Hall of Fame,
    Founding Member
Please post the output from typing
show queueing interface [interface_where_policy_is_being_applied] | include type command.
__
Edison.
yogesh.mhatre Mon, 03/03/2008 - 07:49
Hello Edison,
Thanks for your reply. Here is the output of queue command,
sh queueing interface vlan 200
Interface Vlan200 queueing strategy: none
Yogesh
Edison Ortiz Mon, 03/03/2008 - 08:23
  • Hall of Fame,
    Founding Member
That's the logical interface, I need to know the output from the physical interface.
Better, yet - post the output from typing show module and tell us what linecard is the one used on this policy.
In short, not all modules support priority queueing in egress, I need to find out if you have such module.
__
Edison.
yogesh.mhatre Mon, 03/03/2008 - 08:54
sh module
Mod Ports Card Type Model Serial No.
1 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1033YLHB
2 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1033YLME
3 16 SFM-capable 16 port 1000mb GBIC WS-X6516A-GBIC SAL1133XMYK
4 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1033YLNL
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL11402PEH
7 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL1033YLEB
8 48 SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX SAL11434RQ7
Mod MAC addresses Hw Fw Sw Status
1 0018.ba3c.6780 to 0018.ba3c.67af 11.0 7.2(1) 8.7(0.22)BUB Ok
2 0018.ba3c.6af0 to 0018.ba3c.6b1f 11.0 7.2(1) 8.7(0.22)BUB Ok
3 001c.58d3.aa80 to 001c.58d3.aa8f 4.6 7.2(1) 8.7(0.22)BUB Ok
4 0018.ba3c.6df0 to 0018.ba3c.6e1f 11.0 7.2(1) 8.7(0.22)BUB Ok
5 0016.c85e.e2a8 to 0016.c85e.e2ab 5.4 8.4(2) 12.2(33)SXH1 Ok
7 0018.ba3c.5b30 to 0018.ba3c.5b5f 11.0 7.2(1) 8.7(0.22)BUB Ok
8 001d.a25f.1ff8 to 001d.a25f.2027 11.3 7.2(1) 8.7(0.22)BUB Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B SAL11402TSC 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL11392CPV 3.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Pass
4 Pass
5 Pass
7 Pass
8 Pass
Edison Ortiz Mon, 03/03/2008 - 09:22
  • Hall of Fame,
    Founding Member
Ok, those modules support priority queueing
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/product_data_sheet0900aecd8017376e.html
Configuration on priority queueing for PFC 3B can be found at:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1750910
Keep in mind, QoS on Cat6k is not the same as regular IOS routers while the commands are available on both platforms. To understand QoS in Cat6k I usually find this article quite helpful:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_white_paper0900aecd803e5269.html
HTH,
__
Edison.
