Log in / out of hunt group
Feb 29th, 2008
I would like for users in a hunt group to be able to log in and log out. Is there a softkey that will enable this feature.
We're running CCM5.1. I know softkey "HLog" is available on CCM 4.x but not on 5.x.
Marvin
Overall Rating: 3.8 (3 ratings)
Jaime Valencia Fri, 02/29/2008 - 15:31
The HLog feature is not in all 4.x, just in 4.2(x). It's also available in 6.x, since 4.1(3) was the version they used as base for 5.x that's why it's not there
Jaime Valencia Fri, 02/29/2008 - 15:42
the way we used to make this would be using EM for this purpose, when they log into EM they will be available, if not logged into their EM profile they were offline on the group
Paolo Bevilacqua Fri, 02/29/2008 - 16:13
Not sure why the low rating to the post above that has correct and complete information.
My rating, a '5'.
mlabuguen Fri, 02/29/2008 - 17:13
I was looking for a workaround solution as replied on my next post. Gave HTH another 4 pts for a quick answer. Thanks HTH!
Marvin
