E1
Feb 29th, 2008
pls. interpret or give me informative links for this ...what are the difference bet the two.....thanks
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
Description: DOD to International with PRI link
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20071009, FPGA: 20, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (73 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
25 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
25 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
36151 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
36151 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Sec
E1 0/0/1 is up.
Description: DID for 3777-8700 - 3777-8999
No alarms detected.
Data in current interval (102 seconds elapsed):
7 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
7 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
26 Line Code Violations, 4101 Path Code Violations,
291 Slip Secs, 0 Fr Loss Secs, 1 Line Err Secs, 0 Degraded Mins,
292 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 82398 Unavail Sec
s
Overall Rating: 5 (1 ratings)
mat.walker Mon, 03/03/2008 - 20:43
Whats your config with the D channel of the Serial port and the E1 controller?
I assume your pointing to the Slip Seconds and Errored Seconds problem?
Claudio Quiroz ... Tue, 08/28/2012 - 07:41
Mat.
Korbenda11as simply wants to know what does means each parameter. Otherwise when E1 is up normally or not.
Can you help her?
Claudio from Chile
Chris Deren Wed, 08/29/2012 - 15:49
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Controllers are up which validates L1 is good, next thing would be to validate D channel status on the PRI circuit by issuing "sh isdn status" and ensuring multiple_frames_established is seen.
As to slips, errors, etc that is usually caused by clocking issues, cabling probelms or misconfiguration of isdn switch type for example.
HTH,
Chris
