VACL vs Access-Group
Feb 29th, 2008
I was doing some lab scenarios this afternoon with a couple of layer 3 switches and realized that I can build an access list and apply it to a vlan interface. Since that is the case, what is the logic behind using VACL's?
Edison Ortiz Fri, 02/29/2008 - 21:08
VACLs are processed in hardware in Catalyst switches hence they don't take any CPU cycles. You can run multiple VACLs without affecting the switch utilization.
royalblues Sat, 03/01/2008 - 00:29
Aren't the normal L3 ACLs also compiled in TCAMs and processed in hardware?
Edison Ortiz Sat, 03/01/2008 - 07:29
I was referring mainly on how is done in Cat6k where you have a SP (Switch Processor) and RP (Route Processor). SP handles the VACL while RP handles the L3 ACLs.
