shijomon scaria Fri, 02/29/2008 - 22:11
Thank you sir,
can u please specify the physical connection details..... Actually i need to pass the traffic through both the devices one after another to get the IPS and Anti X features.... Then how should i connet both the devices together??
rleivaoc Fri, 02/29/2008 - 22:26
  • Cisco Employee,
Well, if you are thinking about stacking both devices like so:
ISP-----Out-ASA/IPS-In---Out-ASA/CSC----inside
You can, but you are going to need to think about the overhead the IPS and CSC module scanning is going to create. In addition, you are going to create a more complex configuration on both units for traffic to pass. However, you can limit this by turning off NAT-CONTROL on both units, but, this will create some security concerns.
I hope this helps
shijomon scaria Fri, 02/29/2008 - 23:26
So as u said i can connet both devices back to back, from one's any port to other's any port, isnt it..??
Like
ISP <--> ASA1 GE0
ASA1 GE1 <--> ASA2 GE0
ASA2 GE1 <--> Inside
onlyabhishek007 Fri, 03/07/2008 - 00:13
u can use the on firewall as a routing device and another firewall as a tranparent mode. so the network diagram like
ISP-----> ASA (csc) --------> ASA (aip) transparent ---------> switch
