I have a CSS 11503 running the following service configured:
service server1
ip address 10.1.1.1
keepalive type http
keepalive method get
port 80
keepalive uri "/robots.txt"
active
However, the service shows as down, even though the server is up and running on port 80 and the robots.txt is marked as read-only for anonymous access on port 80 and can be accessed by other servers on port 80 on the same subnet. Then if I do the following:
conf t
service server1
suspend
keepalive type none
active
The service is then forced up, but then if I backout the change:
suspend
keepalive type http
active
the service goes down and then comes backup again and the LB passes traffic to it correctly.
This is the only way I can get the service up, any ideas why this is?
Some background info:
sh ver:
Version: sg0810107s (08.10.1.07s)
Flash (Locked): 07.50.1.03
Flash (Operational): 08.10.1.07
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
Secure Management
Thanks in advance
