Can client get DHCP if the PC has static IP?
Mar 1st, 2008
Hi all,
My case is like as follow:
A switch C2960 is connecting a DHCP server with trunk vlan 2.
If one client PC without static IP is connecting to a vlan-2 port. It can get DHCP IP.
If one client PC with static IP is connecting to a vlan-2 port. However, it can't get DHCP IP.
If the trunk port C2960-to-DHCP server connection changes to access port with vlan 2, it has get DHCP IP again.
Can anyone help me to fix the problem?
Eric
mahmoodmkl Sat, 03/01/2008 - 04:47
  • Gold, 750 points or more
HI
Is the Ip helpder-address configured on u r SVI which is doing intervlan routing.What is the other side config of the switch,verify it is also trunk.
Mahmood
