LACP on 7200-NPE-G1
Mar 1st, 2008
I need to configure LACP on a 7200 to connect it to an alcatel MetroE Sw/Rtr.
I have searched on the SW advisor for an IOS that support this feature, and I have found many images, the problem is that when I use any of all those images they does not have any LACP command (lacp system-priority, show lacp, etc).
Have you configured LACP on this platform? If you know any IOS image that actually support it please let me know.
Thanks in advance.
Alex
owillins Thu, 03/06/2008 - 07:06
  • Silver, 250 points or more
Make sure you are using minimum 12.2(31)SB2. A LACP system priority is configured on each router running LACP. The system priority can be configured automatically or through the CLI. LACP uses the system priority with the router MAC address to form the system ID and also during negotiation with other systems. The LACP system ID is the combination of the LACP system priority value and the MAC address of the router.
