Routing Protocol support for ACE
Mar 1st, 2008
Hi all,
As i am very new to content engines , Just few quick questions:
1. My customer is using OSPF, IMHO , as the ACE is loaded on a C6500, the OSPF will be utilized by the core switch and ACE wil utilize the static routing .
2. In the hardware design , the ACE is "always" place after the MSFC or we need to configure anything specific to place it after the MSFC ?
please do enlighten.
Cheers
Shukla.
Gilles Dufour Sun, 03/02/2008 - 04:35
yes, no routing on ACE. Only static route.
You can also use RHI to inject route into the MSFC.
You don't really need the MSFC, but since you need a default gateway, the MSFC is normally to first choice.
Gilles.
saeed-ahmad Sun, 03/02/2008 - 06:32
Thanx Gilles,
good option , as my cust was asking if we can remove the MSFC and have a direct link to the ACE (So we can ).
Secondly :
1. On the ACE module we have this hidden ports NP1, NP2, ...etc , do we need to configure that or is it used for special cases.
2. In terms of HTTP load balancing to caching-servers, which predictor complies with best practice format, VIP, L4 (src or dst port nos ), L7 ??
3. Cust says, 40% traffic is worm traffic, can DPI (Deep packet inspection) be performed on ACE and some kind of traffic be monitored for worm traffic via 3rd party application.
i know, load of questions.
feel free to answer any of them.
Thanx
Shukla.
