Reverse telnet does not work - hangs at Opening...
thomas_condon
Hey guys, I have a 2610 with IOS 12.0(7) installed and a NM-16A (with two CAB-OCTAL-ASYNC cables connected to some switches and routers). I have configured the lines but am not able to reverse telent to any devices.
The devices range from 2900xl and 2950 switches to 2500/2600/3600 routers.
When I try to reverse telnet, all I get is this message and a blinking cursor:
ACCESS_SERVER#sw1
Trying SW1 (10.10.10.10, 2033)... Open
_
It does the same thing when I try
telnet 10.10.10.10 2033
Here is a copy of the current config:
version 12.0
service nagle
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname ACCESS_SERVER
ip subnet-zero
no ip domain-lookup
ip host R5 2045 10.10.10.10
ip host R4 2044 10.10.10.10
ip host R3 2043 10.10.10.10
ip host R2 2042 10.10.10.10
ip host R1 2041 10.10.10.10
ip host SW5 2037 10.10.10.10
ip host SW4 2036 10.10.10.10
ip host SW3 2035 10.10.10.10
ip host SW2 2034 10.10.10.10
ip host SW1 2033 10.10.10.10
ip host ACCESS_SERVER 10.10.10.10
interface Loopback0
ip address 10.10.10.10 255.255.255.0
no ip directed-broadcast
no ip route-cache
no ip mroute-cache
interface Ethernet0/0
ip address 172.16.11.254 255.255.255.0
full-duplex
interface Serial0/0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Group-Async1
no ip address
group-range 33 48
ip default-gateway 172.16.11.1
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.11.1
ip route 192.168.1.0 255.255.255.0 172.16.11.1
no ip http server
line con 0
exec-timeout 30 0
logging synchronous
login local
transport input none
line 33 48
session-timeout 60
exec-timeout 0 0
transport input all
speed 19200
line aux 0
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input telnet
no scheduler allocate
end
I've read the tech note on Configuring a Terminal/Comm Server and it seems pretty basic but it's just not working as advertised.
The async interfaces show down/down but I'm not sure what config is needed on these?
Also, there are no lights on for the NM-16A so I'm assuming there is something else that needs to be enabled before this will work but I'm not sure what.
I've probably missed something simple even though I've spent 4 hours researching this and troubleshooting to try to get it to work.
Thanks for any help you can provide!
2 Accepted Solutions
try changing the speed on the lines until you get a response. What setting do you use on a laptop if you were to connect directly on these devices ? Use the same setting under line 33-48.
HTH,
__
Edison.
Since the default speed for console connections is 9600 I suspect that Edison got this one. I missed the setting for line speed in the original post. Now it stands out.
Rick
Rick
7 Replies 7
Edison Ortiz
Try no exec and enable flowcontrol hardware under line 33-48.
__
Edison.
I added them but no luck...
By the way, the sessions show up but I can't access them so I end up having to close them down:
ACCESS_SERVER#sh sess
Conn Host Address Byte Idle Conn Name
1 sw1 10.10.10.10 0 0 sw1
2 sw4 10.10.10.10 0 0 sw4
3 sw5 10.10.10.10 0 0 sw5
* 4 sw3 10.10.10.10 0 0 sw3
ACCESS_SERVER#disc 1
Closing connection to sw1 [confirm]
ACCESS_SERVER#disc 2
Closing connection to sw4 [confirm]
ACCESS_SERVER#disc 3
Closing connection to sw5 [confirm]
ACCESS_SERVER#disc 4
Closing connection to sw3 [confirm]
ACCESS_SERVER#
Thomas
I agree with Edison that the command no exec helps a lot and is probably the most often overlooked command when configuring reverse telnet. I hope that adding these commands will overcome your problem.
But I am concerned about your statement saying there are no lights on the async module. It might be helpful if you would post the output of show line and the output of show diag from this router.
The other thing that I have seen that would produce this symptom is confusion about which cable is which and the connection they were trying to make is not connected to the device they expect (or sometimes not connected to any device). Can you verify that the cable connected to SW1 is the first connecting cable in the first octal cable?
Rick
Rick
Thanks Rick,
The commands did not help, but I'm sure they are needed as I'm seeing them in other people's sample configs.
Here's the show line:
ACCESS_SERVER#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
* 0 CTY - - - - - 7 0 0/0 -
33 TTY 19200/19200 - - - - - 4 0 0/0 -
34 TTY 19200/19200 - - - - - 0 0 0/0 -
35 TTY 19200/19200 - - - - - 1 0 0/0 -
36 TTY 19200/19200 - - - - - 1 2993 0/150 -
37 TTY 19200/19200 - - - - - 1 0 0/0 -
38 TTY 19200/19200 - - - - - 0 0 0/0 -
39 TTY 19200/19200 - - - - - 0 0 0/0 -
40 TTY 19200/19200 - - - - - 0 0 0/0 -
41 TTY 19200/19200 - - - - - 0 0 0/0 -
42 TTY 19200/19200 - - - - - 0 0 0/0 -
43 TTY 19200/19200 - - - - - 0 0 0/0 -
44 TTY 19200/19200 - - - - - 0 0 0/0 -
45 TTY 19200/19200 - - - - - 0 0 0/0 -
46 TTY 19200/19200 - - - - - 0 0 0/0 -
47 TTY 19200/19200 - - - - - 0 0 0/0 -
48 TTY 19200/19200 - - - - - 0 0 0/0 -
65 AUX 9600/9600 - - - - - 0 0 0/0 -
66 VTY - - - - - 0 0 0/0 -
67 VTY - - - - - 0 0 0/0 -
68 VTY - - - - - 0 0 0/0 -
69 VTY - - - - - 0 0 0/0 -
70 VTY - - - - - 0 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-32, 49-64
I also verified that the 1st cable (#1) coming from the octal cable is connected to SW1.
Here is the show diag:
ACCESS_SERVER#sh diag
Slot 0:
C2610 1E Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 2.3 Board revision C0
Serial number 2285005415 Part number 73-2839-13
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 91 02 03 88 32 6A 67 49 0B 17 0D 00 00 00 00
0x30: 60 66 65 06 00 00 00 00 00 00 00 00 00 00 00 00
WIC Slot 0:
Serial 1T WAN daughter card
Hardware revision 1.0 Board revision J0
Serial number 25737701 Part number 800-01514-01
Connector type Wan Module
0x20: 01 02 01 00 01 88 B9 E5 50 05 EA 01 00 00 00 00
0x30: 98 00 00 00 01 07 08 01 FF FF FF FF FF FF FF FF
Slot 1:
Async Port adapter, 16 ports
Hardware revision 0.1 Board revision E0
Serial number 25098430 Part number 800-02244-05
Thanks for looking at this for me guys.
Thomas
HTH,
__
Edison.
Rick
Rick
That was exactly it! I changed the speed to 9600 per Rick's suggestion and it worked great.
Thanks for your help guys, working like a champ.
Interestingly, the lights on the asynch lines never light up, even when there is data transfering across the wire. Not sure why not but I'm not worried since the access server is up and running now.
Again, thanks for the help.
Thomas
