ip helper-address - Defining what to forward
Answered Question
Mar 1st, 2008
I setup ip helper-address statements to forward DHCP requests to a central DHCP server which is working great however it is causing problems with Microsoft browser elections in the remote sites.
Is there some way to control what gets forwarded by the ip helper-address command so it only forwards DHCP and not any Microsoft related NetBT broadcasts? Thanks in advance for any help that can be provided.
Riley
Correct Answer by Richard Burts about 9 years 2 months ago
Riley
Your command is not showing up because that port is enabled by default. And in IOS show run typically does not display default values.
And your issue is not so much that you need to forward DHCP as much as it is that you do not want to forward the Windows packets. I would suggest that you configure this:
no ip forward-protocol udp 137
no ip forward-protocol udp 138
Give that a try and let us know if it fixes your problem.
Rick
Correct Answer by Edison Ortiz about 9 years 2 months ago
Riley,
I guess the logic behind this command is that you have to disable the default udp ports which are enabled when configuring ip helper-address.
The default udp ports are listed in the link I provided, there aren't many.
I was able to duplicate what you are seeing in my lab.
HTH,
__
Edison.
Overall Rating: 4.3 (3 ratings)
rileymartin Sat, 03/01/2008 - 15:42
Thanks for the information.
I read the article and if I understand it correctly, I leave the ip helper-address on the interface connecting to the subnet with the PCs and I add the global command: 'ip forward-protocol udp 67' to limit the forwarded protocols to just DHCP. I looked up the RFC 2131 and it says the client sends to port 67 and the server responds to port 68 so I would think that I only need to specify port 67. Is that right?
I added the following command in global configuration mode and it doesn't show up when I do a show run....
I tried adding it again and then doing a show run but it's still not there????
Riley
Correct Answer
Edison Ortiz Sat, 03/01/2008 - 16:22
  • Hall of Fame,
    Founding Member
Riley,
HTH,
__
Edison.
Correct Answer
Richard Burts Sat, 03/01/2008 - 16:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Riley
Rick
rileymartin Sat, 03/01/2008 - 17:44
Ediortiz, Rburts,
Thanks for your help, it's fixed. I disabled all default ports except 67 to reduce the forwarded broadcast traffic.
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
Richard Burts Sun, 03/02/2008 - 04:52
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Riley
I am glad that you got it worked out. And you have effectively reduced the amount of broadcast traffic. Thank you for using the rating system to indicate that your issue was resolved (and thanks for the rating). It makes the forum more useful when people can read about an issue and can know that they will read what successfully resolved the issue.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
