Supervisor Unable to login to supervisor desktop
Answered Question
Mar 1st, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
I have just installed IPCC express 4.0.4.
I have added supervisors to the system.
When I login to the supervisor webpage the credentials work and I am able to dwonload the supervisor dektop.
However after installation, I amunable to loggin. I get the error "the password you entered is incorrect please enter the correct password.
The supervisor log shows the following:
Supervisor ACM0840 Active value 0. Write Active value 1 to the SOFTWARE\Spanlink\TUP registry, then run TUP!
How can I resolve this
Correct Answer by mmelbourne about 9 years 1 month ago
Which password are you using? By default, the initial Supervisor password is the same as the User ID (not the password used for Cisco Agent Desktop). The Supervisor password can be changed within the CSD application.
Please rate helpful posts!
Overall Rating: 5 (4 ratings)
charlesgv Sun, 03/02/2008 - 04:07
You can try this.
Go to the Desktop Administrator on the server. Under Personnel, find the supervisor in question and reset the password from there. Try logging in again using the new password.
Correct Answer
mmelbourne Sun, 03/02/2008 - 06:41
  • Silver, 250 points or more
Ayodeji Okanlawon Sun, 03/02/2008 - 09:15
    2017 IP Telephony
Thanks I was using the AD password but now when I use the user id it works.
