Cisco 837, Access list ?
Mar 2nd, 2008
I've been configuring a cisco 837 router, I'm at a stage were I have the connection test completing with no errors,
Checking interface status... Up
Checking for DNS settings... Successful
Checking interface IP address.. Successful
Checking exit interface... Successful
Pinging to destination host... Successful
but when I try to get on the net my browser willn't open the net. It issues an ip to the desktop and gateway is present, I can ping the router.
Here's my current conf is attached
I thought I needed something like,
access-list 1 permit 192.168.0.0 0.0.0.255 any
I'm still learning so any help would be much appreciated.
aijaz802 Sun, 03/02/2008 - 01:13
  • Bronze, 100 points or more
I think you need to have the ACL 1 like this in global config mode..
Access-list 1 permit 192.168.1.0 0.0.0.255
Access-list 1 permit 190.160.1.0 0.0.0.255
Please check..n rate if it helps...
BR
*aijaz*
m_langdon Sun, 03/02/2008 - 02:57
Thanks for the reply,
I added the lines but still didn't work, could these conflict with others in the list?
Should i delete everything else in the list and just have,
for starters?
aijaz802 Sun, 03/02/2008 - 04:08
In the access list 1 keep only these two lines.... The number "1" refers to the nat statement
ip nat inside source list 1 interface Dialer0 overload
If you change the list number in above nat statement, pls make sure that you have ACL with same number..
By the way why you are using the 190.160.1.0 segment on other Ethernet 2 interface..? just for info..
[Edit]
One more thing, try to remove the access-list 100 and 101 from the two ethernet interfaces n from dialer0 interface [no ip access-group 101 in] and check. The ACL 100,101 might be creating some problem here.
*aijaz*
