FXO disconnect and CPTONE
Mar 2nd, 2008
IOS router is successfull to understand disconnect signal
but it takes 5-7 seconds from disconnect of other side
I attach *.vav file of disconnect signal
here is my config;
voice class dualtone-detect-params 1
freq-max-deviation 20
cadence-variation 20
voice class custom-cptone TT
dualtone disconnect
frequency 450
cadence 220 200 220 200 220 200 620 200
voice-port 2/0/11
supervisory disconnect dualtone mid-call
supervisory custom-cptone TT
supervisory dualtone-detect-params 1
timeouts call-disconnect 3
timeouts wait-release 3
timing hookflash-out 500
connection plar opx 0
description 4283163
station-id name 4283163
caller-id enable
pcameron Mon, 03/03/2008 - 04:45
  • Cisco Employee,
This actually sounds OK - the duration of the disconnect tone is around 1.9 seconds per cycle, and since you have set the timeouts call-disconnect and wait-release on the voice port to 3 seconds, this equates to 5 seconds.
Changing these timers any lower than this often causes unreliable call disconnecting and given that the DSP needs at least one tone cycle to pick up the disconnect tones, so you might have to accept this 5 second disconnect delay.
a.gooding Mon, 03/03/2008 - 07:05
  • Bronze, 100 points or more
i also put in this command under the voice-port, maybe it may help
timing sup-disconnect (i put 100ms)
