CSS redundancy box-to-box
Mar 2nd, 2008
Hello guys,
I'm planning to install 2 redundant load-balancers in a DMZ zone. The CSS units to be installed behind 2 ASA firewalls working in Active/Standby mode. What are the recommendations for these requirements?
1-Do we use the box-to-box redundancy?
2-Do we connect every server to the 2 CSS units with teamed network cards?
3-How does the ASA failover if any of the CSS goes down?
Thanks everybody for you help.
Gilles Dufour Sun, 03/02/2008 - 04:38
box-to-box redundancy is slot to failover compare to vip/interface redundancy.
Moreover, it prevent the use of ASR - so no stateful failover.
Avoid teamed network card with the CSS.
If you want to use such thing, insert a switch between CSS and server.
Don't know anything about ASA failover. Check with the appropriate forum for ASA questions.
sachinga.hcl Fri, 05/29/2009 - 10:27
Hi Georges,
Here is the URL for the configuration for the Configuring VIP and Virtual IP Interface Redundancy follow the configuration guide which may help you
Configuring Box to box redundancy:
CSS 11500 Active-Active Stateful Failover ASR in One-Armed Mode Configuration Example
Box-to-Box Redundancy on the CSS 11xxx Configuration Example - Ciscowiki
Kindly find full range of configuration examples on CSS here :
Cisco CSS 11500 Series Content Services Switches
Configuration Examples and TechNotes
Kindly see URL given below for my other articles
If possible plz rate so that I can be helpful to other people also as it will enhance my credibility.
