Host Not Found - Services
Mar 2nd, 2008
I deployed Extension Mobility before on CCM 4.x and it was working fine and verry straight forward, and same configuration almost on 5.1 but when I go to Services to see it on the phone, I get: Host Not Found.
What can be the problem? as I can not see also other services like: PhoneMessenger.
Fady
Overall Rating: 5 (1 ratings)
Jaime Valencia Sun, 03/02/2008 - 16:37
  • Cisco Employee,
  • Hall of Fame,
    2011
configure the URLs under the enterprise parameters using the ip address from the server and not the hostname from the server
update the config and reset the phones so they download the config files with the new info
