Recording with unity
Answered Question
Mar 2nd, 2008
i am wondering if i can use a call handler to record a welcome prompt.
if yes how can i do it and how can i choose the codec, mono, khz, etc..
and finally where can i find the file that i record it.
Good day
Correct Answer by Jaime Valencia about 9 years 1 month ago
the files should be at x:\commserver\stream files
about the codecs maybe this helps:
Changing the Cisco Unity Codecs
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/unity/42/upgrade/guide/ex/ru_075.html
Overall Rating: 5 (2 ratings)
twissam Sun, 03/02/2008 - 22:23
thanks for your help.
yes it is unity and the link helped a lot.
my question is where this file sits and what codec and other info is there i can change due to requirement.
Good day
