IBM Blade IGSEM - Why can't my upstream ports be 'no shutdown'd on the CLI?
Mar 2nd, 2008
I have 3 IBM H series blade centres with 6 switches in and when I try to configure trunks to the core switches and open them up to participate in VTP and spanning-tree, the error message
"This port cannot be put in to shutdown state" but the port stays in shutdown mode.... Go figure..
Do the switches have to be configured by the Blade centre GUI before they can be managed by the CLI or does the management module have to be configured to release control?
Cheers
Rick
mslavin Tue, 03/04/2008 - 07:25
Hi Rick,
On IBM BladeCenters, on a new install, the Management Module has the uplinks out of the switches shut down, and you can not bring them up from the switch until you enable them the first time from the Management Module GUI. As you had noted, Protected Mode can be part of this, but it does not have to be (and as part of the process of enabling Protected Mode, you have to enable the uplinks via the MM GUI).
On current MM code, enabling the uplinks is done by pointing your browser at the IP address of the MM, logging in, then on the left side, under I/I Module Tasks, select Admin/Power/Restart, then on the right hand side, scroll down until you see "I/O Module Advanced Setup", under here, select the desired module to configure, then set "External ports" to "Enabled", and click Save. At this point the uplinks on the switch will come up, and you can now control them with the normal shut/no shut commands on the switch.
HTH, Matt
r-frank Tue, 03/04/2008 - 14:06
Hi Matt,
Yep I was after the protected mode style of management anyway, but yes you are correct in regards to enabling external ports can be completed via the MMGUI in standard mode, without having to enable protected mode
Cheers
Rick
