Slow Telnet response
Mar 2nd, 2008
I am facing problems while telneting to a remote router which is on a P2P link. Ping response the router is perfectly fine, but the telnet response is absolutely slow. Can any one comment on why this can happen???
fahad.sheikh Sun, 03/02/2008 - 23:17
No!
Here is the config on one end
interface Serial5/6
ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip tcp header-compression iphc-format
ip tcp compression-connections 256
no ip mroute-cache
load-interval 30
no fair-queue
serial restart-delay 0
no dce-terminal-timing-enable
ip rtp header-compression iphc-format
ip rtp compression-connections 1000
end
dongdongliu Mon, 03/03/2008 - 00:37
hi,
i think telnet traffic has been compressed and decompressed.
btw:make sure there are the same CONNECTION NUMBER behind ip tcp compression-connections in local router`s serial interface.
regards
dongdong
aravindhs Mon, 03/03/2008 - 02:56
Also, have you got service nagle enabled or disabled on the routers ?
How is your show ip tcp header-compression looking ?
arav
fahad.sheikh Mon, 03/03/2008 - 19:32
Hi Aravind,
Here is the out put for the command and also I have attached the config for other end.
Router A
Interface Serial5/6 (compression on, IPHC)
Rcvd: 21929 total, 17614 compressed, 0 errors, 6499 status msgs
0 dropped, 0 buffer copies, 0 buffer failures
Sent: 25141 total, 17859 compressed, 0 status msgs, 0 not predicted
596635 bytes saved, 456031 bytes sent
2.30 efficiency improvement factor
Connect: 256 rx slots, 256 tx slots,
2553 misses, 55 collisions, 0 negative cache hits, 256 free contexts
89% hit ratio, five minute miss rate 0 misses/sec, 0 max
Router B
interface Serial2/0
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
load-interval 30
no fair-queue
timeslot 1-31
crc4
no cdp enable
end
TCP/IP header compression statistics:
Interface Serial2/0:
Rcvd: 24316 total, 18933 compressed, 4867 errors
14066 dropped, 0 buffer copies, 0 buffer failures
Sent: 17495 total, 13978 compressed,
486904 bytes saved, 2399219 bytes sent
1.20 efficiency improvement factor
220 long searches, 133 misses 0 collisions
99% hit ratio, five minute miss rate 0 misses/sec, 0 max
