VIC2-2BRI-NT/TE configuration for Cisco 2851
rickyhadlocon
Do you have a sample configuration for VIC2-2BRI-NT/TE? This device is connected to a Cisco 2851 ISR and used for incoming and outgoing calls.
Thank you,
Ricky
6 Replies 6
paolo bevilacqua
Hi, it depends on various things, which country are you in, do the lines have did? That just to begin with.
Thanks. I already configured it and it's now working perfectly.
I spoke to soon. :) I have problems when i unplug the BRI circuits, the link is not turning up.
This is for our Osaka, Japan Office.
Below is my current config:
interface BRI0/0/1
no ip address
isdn switch-type ntt
no isdn spoofing
trunk-group BRI-trunks
Thank you.
Hi, ISDN BRI by nature doesn't go down when unplugged. How many circuits do you have in trunkgroup ? There is a suggested config to work around that, but if you have one circuit only, isn't needed.
Thanks for your reply. I have 4 BRI circuits connected to these devices. All of them are member of the trunk group BRI-trunks.
What else am i missing?
