Modify a tcp idle time-out on ACE
Answered Question
Mar 2nd, 2008
Hi.
I have a question about tcp idle-time out on ace.
I configured like below
set timeout inactivity 600000
class-map match-any TCP_Connection_IP
2 match virtual-address 100.254.130.0 255.255.255.0 tcp any
policy-map multi-match TCP_Connection_Policy
class TCP_Connection_IP
connection advanced-options TCP_Connection_Timer
interface vlan 30(Client Vlan)
service-policy input TCP_Connection_Policy
interface vlan 330(Server Vlan)
Is it a correct?,
If ok, How can I check the tcp-idle?
as show command,
Correct Answer by Gilles Dufour about 8 years 11 months ago
You can't use the virtual-address keyword if you don't want to loadbalance the traffic.
If you just want to the timeout for traffic routed, you need to use a class-map with an acl.
ie:
access-list net1 extended permit tcp any 100.254.130.0 255.255.255.0
class-map net1
match access-list net1
policy-map multimatch TCP_Connection_Policy
class net1
Now, if you have multiple virtual ip address and want to set the timeout for this virtual ip, you have to assign the connection timeout to all individual virtual ip.
You can't do it in one shot like you did.
There is no command to see if a connection has the right idle timeout.
All you can do is a 'show conn detail' and see if the idle timeout increases up to your configured value.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Mon, 03/03/2008 - 01:59
ie:
class-map net1
class net1
Gilles.
