Dust removing
Mar 3rd, 2008
Dear Experts,
Maybe It is so strange question.
We are planning to remove the dust on the Cisco routers and switchs.
Does anyone know that dust removing plan and recomendation protocal?
Thanks advance
aghaznavi Fri, 03/07/2008 - 12:48
  • Silver, 250 points or more
Use the precaution measures when you are touching the internal component.
lamav Fri, 03/07/2008 - 12:51
  • Blue, 1500 points or more
Suck, dont blow. You'll spread the dust around the room. And definitely don't swallow until you're done cleaning.
