ACE-ping to rservers inconsistent
Mar 3rd, 2008
the real servers Inconsistent , sometimes pinging , sometimes request time out
i have three Real Server , it is either all pinging , or all not pinging
if i do clear arp , it is start pinging again
i don't have this issue in the other context ( i have two servers in the other context)
Gilles Dufour Mon, 03/03/2008 - 02:03
  • Cisco Employee,
what ace software version ?
Did you try to take a sniffer trace to see if the server gets the echo request and if it responds ?
Check the server arp table when there is failure.
do you have probes going to those servers?
Gilles.
majaj Mon, 03/03/2008 - 03:13
Software
loader: Version 12.2[120]
system: Version 3.0(0)A1(3b) [build 3.0(0)A1(3b) adbuild_12:39:01-2006/11/14_/auto/adbu-rel/ws/REL_3_0_0_A1_3B]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_3b.bin
installed license: ACE-SEC-LIC-K9 ACE-SSL-05K-K9
1-my ace software is old as you can see above
2- i didn't try sniffer trace
3- i did show arp , the three servers is existing , status UP
4- there is no probe configured yet
many thanks
Gilles Dufour Mon, 03/03/2008 - 05:54
  • Cisco Employee,
I think an upgrade to A1(6.3a) would be the best thing to do first.
There a lot of fixes related to arp since your image.
Gilles.
majaj Mon, 03/03/2008 - 06:40
dear gilles,
thanks for your help
i just upgrade , but the same problem
no continuouse ping
Software
system: Version 3.0(0)A1(6.3a) [build 3.0(0)A1(6.3a) adbuild_02:16:25-2008/
02/02_/auto/adbu-rel3/ws/rel_3_0_0_a1_6.3-throttle/REL_3_0_0_A]
system image file: [LCP] disk0:c6ace-t1k9-mz.3.0.0_A1_6_3a.bin
