How to Configuration Cisco 3725 with NEC ASPILA EX
Answered Question
Mar 3rd, 2008
Dear all;
Now i have Cisco 3725 with 1-Port Channelized E1/T1/ISDN-PRI, i am connect to NEC ASPILA EX with PRI I/F (1PRIU-A1.
The controller link state up, but when clients dialin to RAS not have ring back or not connect to RAS.
anyone can help me?
Correct Answer by Paolo Bevilacqua about 8 years 11 months ago
No slips. Is the problem that the modem connection drops ? Which exact IOS are you running ?
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Mon, 03/03/2008 - 04:34
Are these is isnd data calls? Take "debug isdn q931" with "term mon" to confirm.
Which exact hardware do you have in the 3725 ?
Sopholtum Mon, 03/03/2008 - 06:07
yes, ISDN data call. i'm to debug isdn not have anything alert to terminal, if i'm connected ISDN PRI direct (by pass NEC PBX) to Cisco i work fine.
Paolo Bevilacqua Mon, 03/03/2008 - 06:21
What show isdn status tells you ?
You might need "isdn protocl-emulate network" when connecting via a PBX.
Sopholtum Mon, 03/03/2008 - 09:14
ISDN Controller status is up : that i'm show controller. ok form my picture ....
i'm have onece ISDN PRI form carrer provider, the last it direct to Cisco 3725 + RAS it work fine, and now the onece ISDN connect to NEC PBX and Onece ISDN PRI port of NEC PBX Connect Cisco 3725... it not work, ISDN status is up and when data calling not have respond from cisco. How i can troubbleshooting this solution? can or not?.
Help me Please.
RAS + Controller Config
isdn switch-type primary-net5
controller E1 2/0
line-termination 75-ohm
pri-group timeslots 1-31
interface Serial2/0:15
no ip address
ip nat inside
encapsulation ppp
ip policy route-map nachi-worm
dialer rotary-group 1
dialer-group 1
isdn incoming-voice modem
no fair-queue
no cdp enable
interface Group-Async1
description "Remote Connection for Analog Modem V92"
ip unnumbered FastEthernet0/0
ip access-group 122 in
ip nat inside
encapsulation ppp
ip route-cache policy
dialer in-band
dialer idle-timeout 512 either
dialer-group 1
async default routing
async mode dedicated
peer default ip address pool modem-dialin
no fair-queue
ppp authentication chap
group-range 33 62
hold-queue 10 in
interface Dialer1
description " Remote Connection for ISDN PRI No.=075205600 auto 100 Dialin"
no ip redirects
no ip proxy-arp
ip nat inside
encapsulation ppp
load-interval 30
dialer-group 1
no fair-queue
no cdp enable
ppp authentication chap pap dialin
ppp multilink
Paolo Bevilacqua Mon, 03/03/2008 - 12:49
Hi, as mentioned before when connecting to a PBX usually you need "isdn protocol-emulate network".
Then your show isdn status should show multiframe established, please copy it here.
Sopholtum Mon, 03/03/2008 - 19:41
ok, i will be onsite and keep messeges to you again. wait please.
Sopholtum Tue, 03/04/2008 - 21:42
After i'am connected to PBX ISDN Status is
SSJTrang-ACC-Server#show isdn stat
Global ISDN Switchtype = primary-net5
ISDN Serial2/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x7FFF7FFF
Number of L2 Discards = 0, L2 Session ID = 23
Total Allocated ISDN CCBs = 0
SSJTrang-ACC-Server#show controllers e1 2/0 brief
E1 2/0 is up.
Applique type is Channelized E1 - unbalanced
No alarms detected.
alarm-trigger is not set
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
Module type is Channelized E1/T1 PRI
Version info Firmware: 0000001D, FPGA: 0
Hardware revision is 0.0 , Software revision is 29
Protocol revision is 1
number of CLI resets is 0
receive remote alarm : 0,
transmit remote alarm : 0,
receive AIS alarm : 0,
transmit AIS alarm : 0,
loss of frame : 4,
loss of signal : 4,
Loopback test : 0,
transmit AIS in TS 16 : 0,
receive LOMF alarm : 0,
transmit LOMF alarm : 0,
MIB data updated every 10 seconds.
Data in current interval (297 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
35121 Line Code Violations, 2 Path Code Violations,
0 Slip Secs, 2 Fr Loss Secs, 4 Line Err Secs, 0 Degraded Mins,
4 Errored Secs, 0 Bursty Err Secs, 2 Severely Err Secs, 6074 Unavail Secs
Paolo Bevilacqua Wed, 03/05/2008 - 02:36
Hi, as mentioned twice before, you need to configure "isdn protocol-emulate network" under interface, else the isdn link will never come up. Also, the clock source should be internal.
Sopholtum Thu, 03/06/2008 - 08:38
Hi;
i'am config cisco as you recommended is "isdn protocol-emulate network" and "clock source should be internal". After the remote computer call to RAS it have modem signal and then connected, next time it disconnect. can i change some parameter for this problem or what i'am wrong?. I post config, status, and debug message for you. Help me..
===== show isdn status ===========
#show isdn status
******* Network side configuration *******
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 0
=============== sh controllers e1 2/0 brief ========
#sh controllers e1 2/0 brief
E1 2/0 is up.
No alarms detected.
Framing is CRC4, Line Code is HDB3, Clock Source is Internal.
loss of frame : 1,
loss of signal : 1,
Loopback test : 0,
========== Interface config.=============
controller E1 2/0
clock source internal
no ip address
ip nat inside
encapsulation ppp
dialer-group 1
no fair-queue
no cdp enable
=================Debug Message when call to RAS ===========================
Mar 6 22:40:29 BANGKOK: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x000B
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838B
Exclusive, Channel 11
Calling Party Number i = 0x0081, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x81, '075205600'
Plan:ISDN, Type:Unknown
Low Layer Compat i = 0x8090A3
High Layer Compat i = 0x9181
Mar 6 22:40:29 BANGKOK: ISDN Se2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x800B
Mar 6 22:40:29 BANGKOK: ISDN Se2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x800B
Mar 6 22:40:29 BANGKOK: ISDN Se2/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x800B
Mar 6 22:40:35 BANGKOK: %ISDN-6-CONNECT: Interface Serial2/0:10 is now connected to unknown unknown
Mar 6 22:40:46 BANGKOK: %ISDN-6-DISCONNECT: Interface Serial2/0:10 disconnected from unknown , call lasted 17 seconds
Mar 6 22:40:46 BANGKOK: ISDN Se2/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x800B
Cause i = 0x8290 - Normal call clearing
Mar 6 22:40:47 BANGKOK: ISDN Se2/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x000B
Mar 6 22:40:47 BANGKOK: ISDN Se2/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x800B
Paolo Bevilacqua Thu, 03/06/2008 - 08:56
Hi, please send the complete "show controllers e1", you may be getting slips due to lack not network-clock-participate commands.
Sopholtum Thu, 03/06/2008 - 09:02
The complete "show controllers e1",
E1 2/0 is up.
No alarms detected.
loss of frame : 1,
loss of signal : 1,
Loopback test : 0,
Data in current interval (852 seconds elapsed):
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
8191 Line Code Violations, 0 Path Code Violations
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 166 Unavail Secs
Total Data (last 8 15 minute intervals):
8191 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
Correct Answer
Paolo Bevilacqua Thu, 03/06/2008 - 12:50
Sopholtum Thu, 03/06/2008 - 18:07
IOS is ....
3700 Software (C3725-IPBASE-M), Version 12.3(9e), RELEASE SOFTWARE (fc1)
Sopholtum Fri, 03/07/2008 - 01:02
yes, modem connection drop. IOS is 3700 Software (C3725-IPBASE-M), Version 12.3(9e), RELEASE SOFTWARE (fc1)
Sopholtum Fri, 03/07/2008 - 02:15
i'm not have one more of IOS versions. but i have message post to you two condition are "Remote Computer call form local number of PBX" it work fine, but and "Remote Computer form external" when modem stat "TRAINUP" it disconnect. flowing message ..
====== Remote Computer call form local number of PBX ===============
Mar 7 14:06:37 BANGKOK: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0005
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Progress Ind i = 0x8083 - Origination address is non-ISDN
Low Layer Compat i = 0x9090A3
Mar 7 14:06:37 BANGKOK: Modem 1/9 Mica: configured for Answer mode, with Null signaling, 0x0 tone detection.
Mar 7 14:06:37 BANGKOK: ISDN Se2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8005
Mar 7 14:06:37 BANGKOK: ISDN Se2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8005
Mar 7 14:06:37 BANGKOK: ISDN Se2/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8005
Mar 7 14:06:37 BANGKOK: Modem 1/9 Mica: in modem state CALL_SETUP
Mar 7 14:06:38 BANGKOK: Modem 1/9 Mica: in modem state CONNECT
Mar 7 14:06:38 BANGKOK: Modem 1/9 Mica: in modem state V8BIS_EXCHANGE
Mar 7 14:06:40 BANGKOK: Modem 1/9 Mica: in modem state QUICK_CONNECT
Mar 7 14:06:42 BANGKOK: Modem 1/9 Mica: in modem state RANGING
Mar 7 14:06:43 BANGKOK: %ISDN-6-CONNECT: Interface Serial2/0:10 is now connected to unknown unknown
Mar 7 14:06:45 BANGKOK: Modem 1/9 Mica: in modem state HALF_DUPLEX_TRAIN
Mar 7 14:07:07 BANGKOK: Modem 1/9 Mica: in modem state TRAINUP
Mar 7 14:07:09 BANGKOK: Modem 1/9 Mica: in modem state EC_NEGOTIATING
Mar 7 14:07:09 BANGKOK: Modem 1/9 Mica: in modem state STEADY
Mar 7 14:07:09 BANGKOK: Modem 1/9 Mica: received ConnectInfo
Mar 7 14:07:09 BANGKOK: Modem 1/9 Mica: CONNECT at 31200/28800 (Tx/Rx), V34+, LAPM, V44
Mar 7 14:07:10 BANGKOK: TTY42: DSR came up
Mar 7 14:07:10 BANGKOK: TTY42: no timer type 1 to destroy
Mar 7 14:07:10 BANGKOK: TTY42: no timer type 0 to destroy
Mar 7 14:07:10 BANGKOK: TTY42: no timer type 2 to destroy
Mar 7 14:07:10 BANGKOK: tty42: Modem: IDLE->(unknown)
Mar 7 14:07:11 BANGKOK: Modem 1/9 Mica: PPP escape_map: Tx map = FFFFFFFF, Rx map = 0
Mar 7 14:07:11 BANGKOK: %LINK-3-UPDOWN: Interface Async42, changed state to up
Mar 7 14:07:12 BANGKOK: Modem 1/9 Mica: PPP escape_map: Tx map = 0, Rx map = 0
Mar 7 14:07:12 BANGKOK: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async42, changed state to up
Mar 7 14:07:23 BANGKOK: Modem 1/9 Mica: in modem state SS_RETRAINING
Mar 7 14:07:32 BANGKOK: Modem 1/9 Mica: in modem state STEADY
Mar 7 14:07:32 BANGKOK: Modem 1/9 Mica: Retrained to 31200/28800 (Tx/Rx)
Mar 7 14:07:42 BANGKOK: Modem 1/9 Mica: in modem state SS_RETRAINING
===== > next post for Remote Computer form external message.
Sopholtum Fri, 03/07/2008 - 02:19
========= Remote Computer form external message ===========
Mar 7 14:29:21 BANGKOK: ISDN Se2/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0007
Standard = CCITT
Channel ID i = 0xA9838E
Exclusive, Channel 14
Mar 7 14:29:21 BANGKOK: Modem 1/11 Mica: configured for Answer mode, with Null signaling, 0x0 tone detection.
Mar 7 14:29:21 BANGKOK: ISDN Se2/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8007
Mar 7 14:29:21 BANGKOK: ISDN Se2/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8007
Mar 7 14:29:21 BANGKOK: ISDN Se2/0:15 Q931: TX -> CONNECT pd = 8 callref = 0x8007
Mar 7 14:29:21 BANGKOK: Modem 1/11 Mica: in modem state CALL_SETUP
Mar 7 14:29:22 BANGKOK: Modem 1/11 Mica: in modem state CONNECT
Mar 7 14:29:22 BANGKOK: Modem 1/11 Mica: in modem state V8BIS_EXCHANGE
Mar 7 14:29:26 BANGKOK: Modem 1/11 Mica: in modem state LINK
Mar 7 14:29:27 BANGKOK: %ISDN-6-CONNECT: Interface Serial2/0:13 is now connected to unknown unknown
Mar 7 14:29:31 BANGKOK: Modem 1/11 Mica: in modem state TRAINUP
Mar 7 14:29:33 BANGKOK: ISDN Se2/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0007
Cause i = 0x8090 - Normal call clearing
Mar 7 14:29:33 BANGKOK: %ISDN-6-DISCONNECT: Interface Serial2/0:13 disconnected from unknown , call lasted 12 seconds
Mar 7 14:29:33 BANGKOK: ISDN Se2/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8007
Mar 7 14:29:33 BANGKOK: Modem 1/11 Mica: in modem state TERMINATING
Mar 7 14:29:33 BANGKOK: Modem 1/11 Mica: received TerminateInfo
Mar 7 14:29:33 BANGKOK: ISDN Se2/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0007
Mar 7 14:29:33 BANGKOK: Modem 1/11 Mica: in modem state IDLE
Mar 7 14:29:33 BANGKOK: Modem 1/11 Mica: DISCONNECT after 00:00:11, due to reason (0x7F06) DS1 network disconnect (no carrier)
