Reoccuring message %C4K_REDUNDANCY-5-CONFIGSYNC in logs
Mar 3rd, 2008
We keep getting this message which is filling up the logs every 60 mins.
What is it and what can I do about it?
%C4K_REDUNDANCY-5-CONFIGSYNC: The calendar has been successfully synchronized to the standby supervisor
royalblues Mon, 03/03/2008 - 02:59
  • Green, 3000 points or more
%C4K_REDUNDANCY-5-CONFIGSYNC: The [chars] has been successfully synchronized to
Explanation The configuration has been successfully synchronized to the standby supervisor.
Recommended Action No action is required. This message is informational only.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/system/messages/emsg.html#wp1387942
Narayan
qwertys21 Mon, 03/03/2008 - 03:10
Thanks.
Why does it keep filling up the logs. Is it suppose to be doing this every 60 minutes and sending this message out?
royalblues Mon, 03/03/2008 - 03:25
Yes it does it every 60 minutes
The reason you are seeing this is because you have setup your logging level to greater than 5..
I dont know of a way to stop this message being generated. It would have been great if the IOS too had something like the PIX/ASA where u can use a particular ID and disable the logging
Narayan
aijaz802 Mon, 03/03/2008 - 03:39
  • Bronze, 100 points or more
I hope this helps..
XXX(config)=logging trap errors/warnings....
BR
*aijaz*
aijaz802 Mon, 03/03/2008 - 05:44
The command "logging trap warning" only logs the warning level messages to syslog server this way you wont get the informational level messages, including the message which you are getting every 60 min.
You can configure the trap with various levels.
(config)#logging trap ?
<0-7> Logging severity level
alerts Immediate action needed (severity=1)
critical Critical conditions (severity=2)
debugging Debugging messages (severity=7)
emergencies System is unusable (severity=0)
errors Error conditions (severity=3)
informational Informational messages (severity=6)
notifications Normal but significant conditions (severity=5)
warnings Warning conditions (severity=4)
I hope this clarifies.... Please rate all helpful posts above.
BR
*aijaz*
