Poweredge (Win 2003) port teaming problem with Cat 6509s
Mar 3rd, 2008
One of our server guys has reported a problem with port teaming his Win 2003 Dell servers (running MS Exchange). He has set them up with an active port attached to 6509-A and a standby port attached to 6509-B. The servers have Broadcom NICs. At times the server is completely unavailable - unable to RDP or telnet and users have complained of poor performance.
Does anyone hae any experience - any info gratefully received.
mslavin Sat, 03/08/2008 - 11:08
I'm not so sure CSCsj55739 is the issue. I have a few questions:
1) Can you post a text dump of the Broadcom team config (usually available from the teaming GUI).
2) Are both NICs connected to the same VLAN?
3) Is this same VLAN carried between 6509-A and 6509-B?
4) Have you tried removing the team and putting the team address on one physical NIC at a time, to see if simply one NIC or the other has a connection issue?
faisal_ghaus Sat, 05/31/2008 - 00:41
First of all i beleive you have configured load balanceing means active /active not active passive.
I beleive you should configure failover means active/Passive.
Secondly i beleive both of the ports have to be on same switch and same VLAN for best results
