AP credentials
Answered Question
Mar 3rd, 2008
Today we upgraded the WLC and WCS software of our system to version 5 (latest). Unfortunately we are running into strange behaviour.
A specific problem are the AP credentials.
When we go to an AP directly via a controller we see that 'over-ride global ceredentials' is checked, and a strange username appears; ːëp
When we take a look at the same AP via the WCS, this option is not enabled.
When we try to uncheck the option via the WLC we get the error;
cannot delete globally configured AP.
We are not able to configure a global username/password for AP credentials. There is always some kind of error message.
Anyone experience with this and able to help?
Correct Answer by fielderj about 9 years 1 month ago
TAC found my issue. You cannot have an @ symbol in your passwords. So where the documentation states you need at least 1 Uppercase, 1 lowercase, 1 digit and 1 special charecter in your password...it forgot to mention that you can't use "@" as one of your special charecters.
If you're not using an "@" in your password try changing one of the other special charecters you're using to something else. There might be other undocumented special char's that it doesn't like.
Cheers,
Jeremy
Jeremy
Overall Rating: 5 (1 ratings)
trevorwilson Wed, 03/05/2008 - 12:07
We're running into the same issue... any help would be appreciated...
fielderj Wed, 04/09/2008 - 05:14
Same issue here. When you try to set via controller cli or gui you get this error no matter how strong your password is:
"Use atleast three of the following four classes in the password: lowercase letters,
uppercase letters, digits or special characters"
And when you try to set from WCS you get "Error SNMP operation to device failed: Attempt to set conflicting attribute value"
I have opened TAC case 608361959 on this issue and will post the resolution once i have received one.
Jeremy
Correct Answer
fielderj Wed, 04/09/2008 - 06:08
Cheers,
Jeremy
Jeremy
koksm Mon, 06/09/2008 - 04:07
Finally got the chance to try this myself and indeed, problem solved.
Thnx!!
dennischolmes Mon, 06/09/2008 - 06:56
  • Gold, 750 points or more
Make sure not to use the @ in your SSIDs either. This can cause a reset to factory defaults in the WLC after a reboot. It has to do with the new code being used.
Trending Topics - Security & Network
