waas deployment
Mar 3rd, 2008
in a situation where you have two links: one clear channel e1 and a backup 128k link on your edge router which of it will you set as bandwidth and what happens when the primary link fails will you need to adjust the config on the wae?
umedryk Thu, 03/13/2008 - 07:02
  • Bronze, 100 points or more
Cisco WAAS can be deployed using WCCPV2 as the traffic redirection method. WCCPv2 enables transparent off-path deployment of Cisco WAEs, providing high availability and load balancing. WCCPv2 is a protocol that allows devices such as the Cisco WAE to join service groups with network devices (such as routers or switches) for the purpose of injecting itself into the flow of application traffic to optimize or otherwise manipulate flows. When configured properly, the WCCPv2 process on the network device examines traffic to identify flows related to applications that match the criteria defined in the configured service groups
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/data_sheet_cisco_wide_area_application_services_WAAS_software_version_4_0.html
http://www.cisco.com/en/US/prod/collateral/contnetw/ps5680/ps6870/prod_white_paper0900aecd806d976a.html
