NM-NAM 3.5.1b - Unable to see basic reports
Mar 3rd, 2008
While administering a NM-NAM via the web interface, I encountered a problem related to the report function. While I can see all basic reports just fine in the initial listing, none of those reports show up in the "Report Data" picker that is used to create a custom report (instead of a list of reports, nothing is shown).
The same picker is also shown when viewing a Basic Report. Again, it is blank here as well.
I have tested multiple browsers from multiple workstations using various versions of Java (including the latest version and the recommended version). The above-mentioned Report Data picker remained blank all the time.
Is this a configuration issue? A software glitch?
Thanks for the help!
Joe Clarke Mon, 03/03/2008 - 10:43
This could be a browser/Java issue. What browser are you using? What version of the Java Plug-in do you have installed? Please post the contents of the Java Plug-in console.
dorian.negru Tue, 03/04/2008 - 01:07
I have tried IE 7, Firefox and Mozilla 1.7.13. I also tried various Java versions: 1.3, 1.4, 1.5. Currently using the version posted by Cisco as a requirement.
Here is the Java console output when using IE 7 on Windows 2003 with Java 1.4.2_04 installed. I am not running anything else in the background at the moment of the capture:
Netscape security model is no longer supported.
Please migrate to the Java 2 security model instead.
browser Netscape NS 6
Bad entry data 300%2382%23200%23-%23900||0|n!red|c|1|1|
Set pre-select unknown node 300%2311%23200%23-%23900
Joe Clarke Thu, 03/06/2008 - 08:45
It looks like there may be a problem with one of the basic reports. Please provide a screenshot of your basic reports page.
Joe Clarke Fri, 03/07/2008 - 07:59
Looks like you need to clear the NAM config. If you run "config clear" from the NAM cli, this problem should be resolved. This will fix the report corruption issue.
