Solarwinds showing 6506-E memory used at 92%
Mar 3rd, 2008
  • Silver, 250 points or more
Solarwinds is reporting that teh 6506-E Version 12.2(18)SXF9 is running at 92%. Below is the output of show memory:
System Memory: 524288K total, 252632K used, 271656K free, 1000K kernel reserved.
Am I missing something here?
kailencbi Mon, 03/03/2008 - 11:00
use "show memory free" for an accurate listing of inuse memory on the switch. If the memory is really all being used you can use "show mem summ" or " show proc mem" to find the runaway proscess.
Most likely though the Solarwinds tool is reporting the usage of the I/O memory in use or misreporting. Check with the vendor.
Tshi M Mon, 03/03/2008 - 11:03
BOS32A#sh proc mem
System Memory : 524288K total, 252632K used, 271656K free, 1000K kernel reserved
Lowest(b) : 278147072
