VPN PIX Firewall 6.3(5) issue
Mar 3rd, 2008
Im trying to configure a VPN lan-to-lan in 2 locations.
but this VPN Tunnel is not working, these are the details of the VPN Tunel
crypto map:
Transform-Set 3des, sha, group2, lifetime 3600,the peer, and an access-list (host-to-host)
isakmp pre-share, 3des, sha, df group 2, lifetime 86400.
im getting this in the debug crypto isakmp, could someone know if i am missing some details in the configuration?.
Debug ISAKMP:
ISAKMP (0): processing SA payload. message ID = 0
ISAKMP (0): Checking ISAKMP transform 1 against priority 1 policy
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP: auth pre-share
ISAKMP: life type in seconds
ISAKMP: life duration (basic) of 3600
ISAKMP (0): atts are acceptable. Next payload is 0
ISAKMP (0): processing vendor id payload
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
return status is IKMP_NO_ERROR
crypto_isakmp_process_block:src:xxx.xxx.xxx.xxx, dest:xxx.xxx.xxx.xxx spt:500 dpt:500
OAK_MM exchange
ISAKMP (0): processing KE payload. message ID = 0
ISAKMP (0): processing NONCE payload. message ID = 0
ISAKMP (0): received xauth v6 vendor id
ISAKMP (0): speaking to another IOS box!
ISAKMP (0): speaking to a VPN3000 concentrator
ISAKMP (0): ID payload
next-payload : 8
type : 1
protocol : 17
port : 500
length : 8
ISAKMP (0): Total payload length: 12
OAK_MM exchange
ISAKMP (0): processing ID payload. message ID = 0
ISAKMP (0): processing HASH payload. message ID = 0
ISAKMP (0): remote peer supports dead peer detection
ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of 426085703:19658d47
ISAKMP (0): processing NOTIFY payload 18 protocol 1
spi 0, message ID = 2277627688
return status is IKMP_NO_ERR_NO_TRANS
ISAKMP (0): processing DELETE payload. message ID = 2920063985, spi size = 16
ISAKMP (0): deleting SA: src xxx.xxx.xxx.xxx, dst xxx.xxx.xxx.xxx
ISADB: reaper checking SA 0x13ab0cc, conn_id = 0 DELETE IT!
VPN Peer:ISAKMP: Peer Info for xxx.xxx.xxx.xxx/500 not found - peers:2
ISADB: reaper checking SA 0x12095cc, conn_id = 0
qr_israel Tue, 03/04/2008 - 10:55
The cause of the issue was the remote peer, the parameters of phase 2 were wrong
