CUCM incoming call screening
Mar 3rd, 2008
is it possibile to implement Incoming call screening on CUCM? Kind of black list to block incoming calls based on calling number?
Overall Rating: 3 (1 ratings)
andres.pasten Fri, 05/09/2008 - 07:15
That's a global Call Blocking for all incoming calls from the PSTN, but it's possible to made this on the CCM?
I mean, that in a single IP Phone or in a group of them, I can block or let pass calls an incoming call considering the caller number.
Andres Pasten
Adexus S.A.
Jaime Valencia Fri, 05/09/2008 - 08:45
decisions made on the calling number can only be made on the GW using H323, the CUCM does not have this capability
if this helps, please rate
andres.pasten Fri, 05/09/2008 - 12:11
ok, but with other products like Personal Communicator and Unified Presence, it is possible to implement black/whitelists?
I've not found that those product provides this feature, only a test documents that mention this:
Case Title
White list/Blacklist Creation by Unified Presence Server End User
Verify that a whitelist and a blacklist can be created by a Unified Presence Server end
Call Component Flow
Unified Personal Communicator->
Unified CM->Unified Presence->
Unified Video Advantage
But that doesn't appears on data sheets or presentations for these products.
Andres Pasten
Adexus S.A.
