Problem with Custom Phone Rings
Mar 3rd, 2008
Hi there,
I have an CME 4.1 with IOS 12.4.15T3. I followed the admin guide to implement custom ring tones. I tftp'ed every single file including the ringlist.xml and distinctiveringlist.xml and followed the configuration as mentioned above. Still my 7911G phones do not get any new ringtones. When debugging the TFTP events they also do not request for the ringlist.xml I also factory defaulted a phone and let it get a complete new configuration, but still no ringtones. Maybe somebody got an idea about this ?
paolo bevilacqua Mon, 03/03/2008 - 11:59
  • Hall of Fame,
    Founding Member
Hi, the 7911 do request ringlist.xml only when you enter user preferences menu, ringtones precisely. Check again and you should see that.
mamkreutz01 Mon, 03/03/2008 - 12:05
How do you mean that ? When i go into user preferences and then select ringtones i only see the two default ringtones chirp1 and chirp2. I do not see any other options there to download the ringlist.xml ? Where can i find that then ?
paolo bevilacqua Mon, 03/03/2008 - 12:09
  • Hall of Fame,
    Founding Member
What I mean, is that the tftp request is sent at the time you enter that menu. But check that you see all the tftp request correcty, like where restarting phone for example.
mamkreutz01 Mon, 03/03/2008 - 12:18
Ah ok. I only looked at the TFTP debug events when restarting the phone and then it is not displayed. But also in the status messages it is not displayed.
paolo bevilacqua Mon, 03/03/2008 - 12:35
  • Hall of Fame,
    Founding Member
Do "term mon" to see debug output via telnet.
If still you don't see it, check your "logging" configuration.
mamkreutz01 Mon, 03/03/2008 - 13:03
Ok did that, look below for the results:
VDKNUTH(config)#ephone 19
VDKNUTH(config-ephone)#restart
restarting 001D.450B.D17D
Mar 3 20:55:51.525: //PRESENCE:[0]:/presence_line_update: SCCP, no update
Mar 3 20:55:51.525: ephone-19[10][SEP001D450BD17D]:skinny_unsubscribe_blf
Mar 3 20:55:51.525: %IPPHONE-6-UNREGISTER_NORMAL: ephone-19:SEP001D450BD17D IP:
10.10.10.11 Socket:10 DeviceType:Phone has unregistered normally.
Mar 3 20:55:51.669: TFTP: Looking for CTLSEP001D450BD17D.tlv
Mar 3 20:55:51.761: TFTP: Looking for SEP001D450BD17D.cnf.xml
Mar 3 20:55:53.049: TFTP: Opened system:/its/XMLDefault7911.cnf.xml, fd 0, size
1220 for process 309
Mar 3 20:55:53.057: TFTP: Finished system:/its/XMLDefault7911.cnf.xml, time 00:
00:00 for process 309
Mar 3 20:55:59.393: TFTP: Looking for SCCP11.8-2-2SR1S.loads
Mar 3 20:55:59.493: TFTP: Opened usbflash1:/phone/7906-7911/SCCP11.8-2-2SR1S.lo
ads, fd 0, size 662 for process 309
Mar 3 20:55:59.493: TFTP: Finished usbflash1:/phone/7906-7911/SCCP11.8-2-2SR1S.
loads, time 00:00:00 for process 309
Mar 3 20:55:59.925: TFTP: Looking for Jar11sccp.8-2-2ES1.sbn
Mar 3 20:56:00.177: TFTP: Opened usbflash1:/phone/7906-7911/jar11sccp.8-2-2ES1.
sbn, fd 0, size 377390 for process 309
Mar 3 20:56:01.489: TFTP: Finished usbflash1:/phone/7906-7911/jar11sccp.8-2-2ES
1.sbn, time 00:00:01 for process 309
Mar 3 20:56:02.833: TFTP: Looking for cnu11.8-2-2ES1.sbn
Mar 3 20:56:03.089: TFTP: Opened usbflash1:/phone/7906-7911/cnu11.8-2-2ES1.sbn,
fd 0, size 439073 for process 309
Mar 3 20:56:04.621: TFTP: Finished usbflash1:/phone/7906-7911/cnu11.8-2-2ES1.sb
Mar 3 20:56:05.913: TFTP: Looking for apps11.8-2-2ES1.sbn
Mar 3 20:56:06.169: TFTP: Opened usbflash1:/phone/7906-7911/apps11.8-2-2ES1.sbn
, fd 0, size 2455679 for process 309
Mar 3 20:56:15.069: TFTP: Finished usbflash1:/phone/7906-7911/apps11.8-2-2ES1.s
bn, time 00:00:08 for process 309
Mar 3 20:56:21.417: TFTP: Looking for dsp11.8-2-2ES1.sbn
Mar 3 20:56:21.669: TFTP: Opened usbflash1:/phone/7906-7911/dsp11.8-2-2ES1.sbn,
fd 0, size 302171 for process 309
Mar 3 20:56:22.689: TFTP: Finished usbflash1:/phone/7906-7911/dsp11.8-2-2ES1.sb
Mar 3 20:56:23.761: TFTP: Looking for cvm11sccp.8-2-2ES1.sbn
Mar 3 20:56:24.013: TFTP: Opened usbflash1:/phone/7906-7911/cvm11sccp.8-2-2ES1.
sbn, fd 0, size 2146813 for process 309
Mar 3 20:56:31.841: TFTP: Finished usbflash1:/phone/7906-7911/cvm11sccp.8-2-2ES
1.sbn, time 00:00:07 for process 309
Mar 3 20:57:45.210: TFTP: Looking for CTLSEP001D450BD17D.tlv
Mar 3 20:57:45.266: TFTP: Looking for SEP001D450BD17D.cnf.xml
Mar 3 20:57:45.266: TFTP: Opened system:/its/XMLDefault7911.cnf.xml, fd 0, size
Mar 3 20:57:45.286: TFTP: Finished system:/its/XMLDefault7911.cnf.xml, time 00:
Mar 3 20:57:46.374: TFTP: Looking for Netherlands/g3-tones.xml
Mar 3 20:57:46.378: TFTP: Opened flash:/g3-tones.xml, fd 0, size 769 for proces
s 309
Mar 3 20:57:46.382: TFTP: Finished flash:/g3-tones.xml, time 00:00:00 for proce
ss 309
Mar 3 20:57:46.718: %IPPHONE-6-REG_ALARM: 25: Name=SEP001D450BD17D Load= SCCP11
.8-2-2SR1S Last=Initialized
Mar 3 20:57:46.750: %IPPHONE-6-REGISTER: ephone-19:SEP001D450BD17D IP:10.10.10.
11 Socket:10 DeviceType:Phone has registered.
Mar 3 20:57:46.766: ephone-19[10][SEP001D450BD17D]:skinny_unsubscribe_blf
Mar 3 20:57:56.486: //PRESENCE:[0]:/presence_line_update: SCCP, no update
mamkreutz01 Tue, 03/04/2008 - 23:01
Hi there, somebody has an clue what could be the problem ?
