Catalyst 6500 Input Errors
Mar 3rd, 2008
A port connected on my 6500 connected to a 3750 has lots of errors. Here is the output from a show interface:
GigabitEthernet1/7 is up, line protocol is up (connected)
Hardware is C6k 1000Mb 802.3, address is 0011.938a.6032 (bia 0011.938a.6032)
Description: To SW560CRG Pri
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 241/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is SX
input flow-control is off, output flow-control is off
Clock mode is auto
Last input 00:00:55, output 00:00:51, output hang never
Last clearing of "show interface" counters 00:50:04
Input queue: 0/2000/23107/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 751000 bits/sec, 113 packets/sec
5 minute output rate 300000 bits/sec, 152 packets/sec
255165 packets input, 147281086 bytes, 0 no buffer
Received 926 broadcasts (758 multicasts)
439 runts, 0 giants, 0 throttles
23107 input errors, 10546 CRC, 11002 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
430012 packets output, 120890205 bytes, 0 underruns
Any idea where to start? The 3750 does not show any errors on its side of the trunk, just the 6500.
lamav Mon, 03/03/2008 - 10:14
Before reinventing the wheel, I would recommend checking speed and duplex settings on both ends and making sure they match.
Then try replacing cable.
Come back and let us know what happens.
Victor
