How to know the feature set and the last ios for a switch
Mar 3rd, 2008
The customer has an old catalyst 5500, and wishes to do an upgrade to the last version, but I was not able to find what is the feature set that he can download the ios. The show version displays the following:
IOS (tm) C5RSM Software (C5RSM-DSV-M), Version 12.0(28b), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Sat 08-Jan-05 03:09 by kellmill
Image text-base: 0x60010930, data-base: 0x60C0C000.
The modules are:
Mod Module-Name Ports Module-Type Model Serial-Num Status
1 2 10/100BaseTX Supervis WS-X5530 010817422 standby
2 2 10/100BaseTX Supervis WS-X5530 009609900 ok
3 12 10/100BaseTX Ethernet WS-X5203 008720865 ok
4 24 10/100BaseTX Ethernet WS-X5224 008722151 ok
5 24 10/100BaseTX Ethernet WS-X5224 009043000 ok
6 1 Route Switch WS-X5302 028990558 ok
7 24 10/100BaseTX Ethernet WS-X5234 020246602 ok
Mod MAC-Address(es) Hw Fw Sw
1 00-90-bf-2f-80-00 to 00-90-bf-2f-83-ff 2.0 3.1.2 4.5(6a)
2 00-90-bf-2f-80-00 to 00-90-bf-2f-83-ff 1.8 3.1.2 4.5(6a)
3 00-10-7b-53-98-a0 to 00-10-7b-53-98-ab 1.2 3.1(1) 4.5(6a)
4 00-10-7b-69-66-28 to 00-10-7b-69-66-3f 1.4 3.1(1) 4.5(6a)
5 00-10-7b-69-66-40 to 00-10-7b-69-66-57 1.4 3.1(1) 4.5(6a)
6 00-e0-1e-39-97-8e to 00-e0-1e-39-97-8f 7.7 20.22 12.0(28b)
7 00-01-63-54-93-b0 to 00-01-63-54-93-c7 2.0 4.5(2) 4.5(6a)
Edison Ortiz Mon, 03/03/2008 - 10:55
Based on C5RSM-DSV-M, that feature set is Desktop/IBM
The latest version (12.2.46) does require more DRAM (64/16) vs your current IOS (32/16)
HTH,
__
Edison.
glen.grant Mon, 03/03/2008 - 15:56
Everything depends on how much dram you have on both the RSM card also the supervisor card. If you have enough dram on the supervisor the last version is 6.4.23a (64 meg dram). For the RSM if you have enough dram then 12.2.46a was the last code (64 meg dram).
