BGP Dampening; Not seeing dampening process
Answered Question
Mar 3rd, 2008
I've configured 2 routers and using FR in between. Each router advertising its own network and I've activated default bgp dampening on one of the router.
The problem is I can't see the dampening process using "debug ip bgp damp", "sh ip bgp sum", "sh ip bgp damp fla" when I shut/unshut lo0 and adjacency network.
as5r1(config-router)#do sh run | s router bgp
router bgp 5
no synchronization
bgp log-neighbor-changes
bgp dampening
network 5.5.5.0 mask 255.255.255.0
network 5.5.5.1 mask 255.255.255.255
neighbor 5.5.5.34 remote-as 3
no auto-summary
as5r1(config-router)#do sh ip int brief
FastEthernet0/0 unassigned YES NVRAM administratively down down
Serial1/0 unassigned YES NVRAM up up
Serial1/0.407 5.5.5.33 YES NVRAM up up
Serial1/1 unassigned YES NVRAM administratively down down
Serial1/2 unassigned YES NVRAM administratively down down
Serial1/3 unassigned YES NVRAM administratively down down
Loopback0 5.5.5.1 YES NVRAM up up
as5r1(config-router)#do sh ip bgp damp para
dampening 15 750 2000 60 (DEFAULT)
Half-life time : 15 mins Decay Time : 2320 secs
Max suppress penalty: 12000 Max suppress time: 60 mins
Suppress penalty : 2000 Reuse penalty : 750
BGP table version is 30, local router ID is 5.5.5.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 3.3.3.0/24 5.5.5.34 0 0 3 i
*> 5.5.5.0/24 0.0.0.0 0 32768 i
*> 5.5.5.1/32 0.0.0.0 0 32768 i
as5r1(config-router)#do sh ip bgp sum
BGP router identifier 5.5.5.1, local AS number 5
BGP table version is 30, main routing table version 30
3 network entries using 351 bytes of memory
3 path entries using 156 bytes of memory
3/2 BGP path/bestpath attribute entries using 372 bytes of memory
1 BGP AS-PATH entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 903 total bytes of memory
Dampening enabled. 0 history paths, 0 dampened paths
BGP activity 5/2 prefixes, 16/13 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
5.5.5.34 4 3 51 60 30 0 0 00:25:09 1
Correct Answer by Harold Ritter about 8 years 11 months ago
David,
How do you simulate the BGP prefix flapping? Bear in mind that if you just shutdown the interface between the two routers it will not trigger BGP dampening as it is the BGP session that will be flapping rather than the BGP prefixes themselves.
I would suggest you just remove the network statement and reinstate it and repeat this process a couple of times, which should cause BGP dampening to kick in.
Hope this helps,
Overall Rating: 5 (2 ratings)
ebreniz Fri, 03/07/2008 - 14:23
I think you may have to set the dampening parameters in the route-map.. I may well be wrong but thats all I can think of...
try this:
route-map BGP-damped permit 10
match ip address prefix-list BGP-damped
set dampening XXXXXXX
exit
where 15 is the half-life decay time
and 750 is the re-use time of the dampened route
and 2000 is the value when the route starts dampening
and 60 is the max time (in mins) to suppress the route...
set some parameters like half-life , penalty to start reusing a route , penalty to start suppressing a route , Maximum duration to suppress a stable route
Correct Answer
Harold Ritter Fri, 03/07/2008 - 17:10
David,
Hope this helps,
davidsudjiman Tue, 03/11/2008 - 22:32
Thanks hritter!
Apparently your suggestion works. Removing advertised network via "no net" does the job.
Danilo Dy Tue, 03/11/2008 - 07:17
Try multiple hard BGP reset on router without BGP dampening setting, i.e. "clear ip bgp *" to see if BGP dampening settings works on the router with BGP dampening setting.
This happens to me when I'm new to BGP :) which I learned to use soft BGP reset.
Dandy
