I am trying to put together a config for a 2960 switch (running 12.2(25)SEE3 C2960-LANBASE-M) that will give priority to voice packets which are already marked with DSCP 40 by the VoIP phone systems. I have successfully used Cisco 2950 switches to do this in the past so I want to ensure that my 2960 will do the same job.
There is a 3662 router connected to Fast0/1 that connects off to a number of other sites that run the same model VoIP PBX. The local VoIP PBX connects to Fast0/2. Gig0/2 links down to a Cisco 2950 that has a VoIP analogue phone module.
I have posted the relevant parts of my config file below:-
hostname switch16
mls qos
interface FastEthernet0/1
description To Cisco 3662
switchport mode trunk
srr-queue bandwidth share 30 20 25 25
priority-queue out
mls qos trust dscp
interface FastEthernet0/2
description To VoIP phone system
priority-queue out
mls qos trust dscp
interface FastEthernet0/3
spanning-tree portfast
interface FastEthernet0/24
interface GigabitEthernet0/2
description To Parts Cisco 2950
priority-queue out
mls qos trust dscp
end
Am I doing the right thing by using the priority queue command?
Should I be doing anything to the ingress queues as well?
Any thought / suggestions are gratefully received.
