50% IPv6 Lost Packets on 6509 Supervisor 720 3Bs!!!
dkling
Hey all,
> > I'm having packet loss issues through two 6509s connected back to back,
> > described below. No matter what rate, 10 meg up to 1000 meg, I'm getting
> > about 50% packet loss using a Smartbits 6000C to generate IPv6 traffic on
> > Vlan 30 and receiving the unicast stream on Vlan 50 with 1024 or 1500 frame
> > sizes. The two CAT 6509s have Sup 720 3Bs and 12.2(18)sxd7b loaded on
> > them. It seems everything pings through fine and routing is correct, hell
> > it's only one hop, but whenever I run Smartbits I get crappy results. I
> > used OSPFv3 and even tried static, but layer 3 seems fine as I can ping vlan
> > 50 sourced from vlan 30 and vice versa. I turned on "ipv6 cef distributed"
> > and " ipv6 mfib hardware..." and it did nothing. I'm wondering if anyone
> > here can check my config and notice anything I missed or forgot to turn on
> > or maybe it's the smartbits testing gear that is screwed. I did hookup the
> > Smartbits through just one 6509 on two ports and it was fine, so I don't
> > think it is the test gea!
> > r. Forgive any typos, I'm typing this out of my head, for certain reasons
> > I can't copy and xfer the configs from the switches here.
> > No errors on any interfaces either. sh ipv6 route shows the correct
> > routes learned via ospf with the correct link-local ont he other side of
> > g1/48. Also, the link-local is resolving, verified with "sh ipv6
> > neighbors". I'm pulling my hair out and I hope somebody can help me,
> > thanks!! And this is the latest IOS in the train we use. :\
> > Vlan 30 ---> 6509A <--GigE--> 6509B <--- Vlan 50
> > 6509A
> > ipv6 unicast-routing
> > ipv6 mfib hardware
> > int vlan 30
> > ipv6 address 2001:480::1/64
> > ipv6 ospf 200 area 0
> > int g1/48
> > description Connection to 6509B
> > ipv6 address 2001:480:250:1::2/64
> > int g2/41
> > description Connection to Test Gear
> > switchport access vlan 30
> > switchport mode access
> > speed 1000
> > duplex full
> > 6509B
> > ipv6 mfib hardware
> > int vlan 50
> > ipv6 address 2001:480:2::1/64
> > int g1/48
> > description Connection to 6509A
> > ipv6 address 2001:480:250:1::1/64
> > int g2/41
> > switchport access vlan 50
> > speed 1000
> > duplex full
> > Thanks,
> > Dale
gearnsc
I've seen similar problems in other implementations, try shutting cef off completely and run your tests again.
I shutoff route-cache cef on the interfaces because the switch won't let me turn cef off globally. I get an error message stating it's not allowed to be turned off on this device. Guess I'm going to have to try different code now.
