LWAPP client disconnecting from Terminal service(Remote Desktop Connection)
Mar 3rd, 2008
HI all,
We are using WiSM(ver 4.2.99), LAP1131AG, ACS4.1(PEAP, MSCHAPv2) and
interworking with Active Directory.
The WLAN service and client authentications are working very well. The wireless encryption
is WPAv1 (TKIP).
The problem is taht the wireless client using MS Wireless Zero Configuraion drop from
terminal service pc which is also using WZC.
If i connect terminal pc changed wirelss to wired, the session is not disconnecting.
I thnk this issue come from TKIP encryption and LWAPP Tunneling.
sabhasin Sat, 03/08/2008 - 19:50
there could be a number of things that's affecting these clients (I wouldn't blame "LWAPP tunneling" just yet). Have you had a chance to capture some over-the-air packets? What about the RF side of things with a spectrum analyzer? Also, another thing you might try is pick one of these poorly performing clients and run a debug on its mac address, on the WLC (debug client ). We'll have more to work on from there...
George Stefanick Mon, 03/10/2008 - 00:58
When you say you drop terminal services, are you losing wireless client / access point connectivity during this drop? Perhaps interference where an elevated noise floor is causing a short moment of wireless loss.
yong1794 Mon, 03/10/2008 - 20:07
Thanks reply.
I don't think the noise issue in here cause other remote access utilities like RealVNC, PCAnywhere are not happen disconnection problem.
Only wireless remote desktop hosting pc(windows XP) is dropping a few senconds later from LWAPP AP whenever wired and wireless user connected it.
sabhasin Mon, 03/10/2008 - 20:20
how often is the disconnect? (random or at consistent intervals?) could you, if possible, try to capture some packets when this happens?
yong1794 Tue, 03/11/2008 - 02:04
The disconnection happen whenever wired and wireless client are connecting wireless remote desktop hosting LWAPP client (windows XP). The hosting client is re-association a few seconds later after disconnected.
We are using a controller image version 4.2.99.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
