03-03-2008 07:40 PM - edited 03-05-2019 09:31 PM
one IP is pinging from my desktop but not pinging from switch. what may be the problem. default route is configured in switch.
03-03-2008 08:21 PM
Hi Goutam,
This is very little information about your configs.
Do you ping this IP address with source addresses that are in the same subnet?
How does your config looks like at all?
Istvan
03-03-2008 08:49 PM
yes I am pinging the IP ( 10.226.x.13 & 10.225.x.13) with source of my switch ip ( 10.163.x.254) my switch ip is in different subnet and destination ip is in different subnet. But in my firewall both IPs are accepting ICMP & Tracert.
03-03-2008 08:56 PM
Hi Goutam,
Please check if the routers that are included in the traffic path all have the routes in their routing tables pointing back to your source subnet.
The icmp replies need a path from the destination subnet back to the source subnet.
Istvan
03-03-2008 08:58 PM
Thank for your help
03-03-2008 09:01 PM
Hi Goutam,
Could please inform me back if my advice solved the problem :).
Thanks in advance:
Istvan
03-03-2008 09:05 PM
yes solved the problem
03-03-2008 09:43 PM
OK Goutam,
I'm glad I could help you.
Cheers:
Istvan
