What is the difference between models?
Mar 3rd, 2008
I bought a used AIR-AP1232AG-A-K9 Cisco Aironet 1200 AP W/ A & G Radios and when it arrived I noticed the stickers on the back said:
Is this an AIR-AP1232AG-A-K9? If not, what is it and what's the difference? Thanks to anyone who is familiar with this equipment and can straighten me out.
rghernandez Tue, 03/04/2008 - 03:03
the AIR-AP1232AG-A-K9 is the US version of the Cisco 1242AG
The AIR-AP1210 is the platform version/series
the AIR-RM20A-A-K9 Is the internal A radio module and
the AIR-MP20B-A-K9 Is the internal B radio module. With these devices in your access point you can run A, B, and G devices. the sticker is just stating what radio modules are installed in the device. yes this is a 1232ag access point.
Hope this helps.
rileymartin Tue, 03/04/2008 - 04:01
Thank you for clearing that up. I searched for AIR-AP1231AG-A-K9 and all I could find were articles about using this number when requesting an RMA and nothing that explained whether or not it was the same thing. Thanks again.
rileymartin Tue, 03/04/2008 - 07:22
I did password recovery on the AIR-AP1232AG-A-K9 and now I'm reading 'Cisco IOS Wireless LAN Configuration Guide Release 12.4T' trying to learn how to do the config. After the password recovery I reset the con, vty and enable secret passwords and when I did a sh run there was 'more' in the config than I was expecting. I attached the config. Is this the default config that the unit comes with or is this left over from its previous environment. I'm learning this all for the first time so I'm really clueless. Thanks for any insight you can provide.
