Giga Etherchannel
Mar 3rd, 2008
Hi to all,
I would like to know if the FIBER & UTP (Catalyst 3560 Fiber SFP & 1000Base-T SFP) connection can be configured as GIGA ETHERCHANNEL?
Hope you could help me on this!!!
Raymond
massimiliano.se... Mon, 03/03/2008 - 22:46
  • Silver, 250 points or more
The ports must be of the same type.
"Configure a PAgP EtherChannel with up to eight Ethernet ports of the same type"
"Configure a LACP EtherChannel with up to 16 Ethernet ports of the same type."
Reference: http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.1_19_ea1/configuration/guide/swethchl.html#wp1116631
I hope this helps.
Best regards.
Massimiliano.
aijaz802 Mon, 03/03/2008 - 23:08
  • Bronze, 100 points or more
As far as I know you can create a ether channel as long as the physical ports are having identical speed/duplex settings, irrespective of the physical media. you can bundle gigabit ethernet port from Fiber SFP and gigabit port from 1000base-t-sfp to form an ether channel.
I hope this helps...pls rate if it helps..
BR
*aijaz*
mon_samonte Mon, 03/03/2008 - 23:50
Hi aijaz,
You mean to say that it is posible to create an Gigabit Etherchannel even the media type (Fiber & UTP) is not similar???
Thanks for the help guys...
Raymond
Jon Marshall Tue, 03/04/2008 - 00:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Raymond
Yes you can do this. As long as the speed/duplex of the ports is the same you should be fine.
Jon
mon_samonte Tue, 03/04/2008 - 00:52
Thanks for your reply Sir jon.marshall.
I Haven't tried it yet but I will update you if it will work.
Thanks again to all who attend to my question.
Best Regards,
Raymond
albert_coll Fri, 09/12/2008 - 01:52
The document "System Requirements to Implement EtherChannel on Catalyst Switches", states that in Catalyst 6500/6000 Series Switches that Run Cisco IOS Software, the Ethernet interfaces that participate in an EtherChannel can include both the copper and fiber-optic ports.
Reference: http://www.cisco.com/en/US/partner/tech/tk389/tk213/technologies_tech_note09186a0080094646.shtml#topic2
Be aware that this feature seems to be specific for platforms Cat6500 running IOS.
