PIX 501 Web Server Inside
Mar 3rd, 2008
I have a PIX 501 and a webserver Inside with the following ip addresses:
yyy.yyy.yyy.201 Web server nic ip addr.
yyy.yyy.yyy.200 Pix inside ip addr.
xxx.xxx.xxx.81 Router inside ip addr.
xxx.xxx.xxx.82 Pix outside ip addr
xxx.xxx.xxx.84 Public Web server ip (BIND)
I am unable to see my web server.
This is my configuration:
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ooooooooooooo encrypted
passwd ooooooooooooo encrypted
hostname pix
domain-name cisco.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_in permit icmp any host xxx.xxx.xxx.44 echo-reply
access-list outside_in permit tcp any interface outside eq www
access-list outside_in permit tcp any interface outside eq https
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside xxx.xxx.xxx.42 255.255.255.248
ip address inside yyy.yyy,yyy.200 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location yyy.yyy,yyy.40 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www yyy.yyy,yyy.201 www netmask
255.255.255.255 0 0
static (inside,outside) tcp interface https yyy.yyy,yyy.201 https netmask
255.255.255.255 0 0
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.41 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http yyy.yyy,yyy.40 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Any syggestions?
Thank you
Dimitris
husycisco Tue, 03/04/2008 - 03:14
  • Gold, 750 points or more
Hi Dimitris
You forgot to assign the ACL to interface
access-group outside_in in interface outside
Dimitris Mingos Tue, 03/04/2008 - 07:48
I did but I do not have any result.
Am I missing anything else?
Pls be specific.
The new config is:
PIX Version 6.3(3)
enable password oooooooooooooo encrypted
passwd oooooooooooooo encrypted
hostname pix
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address inside yyy.yyy.yyy.200 255.255.255.0
pdm location yyy.yyy.yyy.40 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
http server enable
http yyy.yyy.yyy.40 255.255.255.255 inside
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxx
added lines
Dimitris
husycisco Tue, 03/04/2008 - 09:24
Dimitris,
Try running " clear xlate ". This will drop connections temporarily. If doesnt work, try "no fixup protocol http 80". If stilld oesnt work, please attach your full config with IPs and without the encrytption hash of your enable and user passwords.
jojuarez Sat, 03/08/2008 - 19:45
The second configuration you attached doesn't even have static translations. I don't like to use letters so let's suppose the private IP of the server is 192.168.1.1. You're using the IP address of the outside interface so:
static (inside, outside) tcp interface 80 192.168.1.1 80
access-l outside_in permit tcp any interface outside eq 80
access-g outside_in in int outside
clear xlate
If you're still unable to access the web server, you need to run traffic captures in order to figure out what the problem is.
