managment ip
aijaz802 Tue, 03/04/2008 - 02:34
once u login to the switch thru console goto the "configuration menu", then "IP Configuration menu", here you have option to provide ip address,subnet mask n gateway...
You can configure the mgmt vlan ip as shown below..
interface Vlan1
no shutdown
ip address
You can check the following link for more information...
Pls rate if it helps..
glen.grant Tue, 03/04/2008 - 17:50
Yes it can , this is for switch mgt. only and has no routing function .
