vlan MTU, interface vlan mtu and hardware mtu
Mar 4th, 2008
I use two 7600 as P routers.
These are configured with routed interfaces:
interface Gi2/1
mtu 1520
interface Gi2/1.15
no switchport
ip address 1.2.3.4 255.255.255.0
mpls ip
Now want to use SVI:
vlan 1145
mtu 1520
interface vlan 1145
tag-switching ip
mtu 1520
conf t
interface Gi2/1
switchport
switchport trunk allowed vlan 1145
switchport mode trunk
switchport nonegotiate
mtu 9216
no ip address
speed nonegotiate
no shutdown
I understand mtu 9216 as the hardware mtu.
1520-sized ICMP packets with df-bit are ok with:
vlan 1145
mtu 1520
interface vlan 1145
mtu 1520
and also ok with:
vlan 1145
mtu 1500
interface vlan 1145
mtu 1520
but not OK if the mtu on interface vlan 1145 is not 1520.
So, what is the difference between the mtu 1520 command under interface vlan 1145 and the mtu 1520 command under vlan 1145 configuration ?
Is there any issues (performances) using 7600 as P router with SVI ?
william.caban Tue, 03/04/2008 - 04:50
When you set the vlan mtu you are configuring the maximum PDU that the specific vlan will be able to transit. When you set the mtu on an SVI you are configuring the max PDU you are able to receive in your Layer3 from that vlan.
"A packet's MTU is not checked on the ingress side of an SVI. However, it is checked on the egress side of an SVI. If the packet's MTU is larger than the egress SVI's MTU, the packet is fragmented by software (if the DF bit is not set)."
http://www.cisco.com/warp/public/473/175.html
-W
