Running Text
Mar 4th, 2008
I want to make a running text on the ip phone screen, i can't make a delay while moving the letters, setTimeout() is not working, please tell me what alternative function to use.
Mike-1985 Tue, 03/04/2008 - 03:58
You can ONLY send static text / pictures / menu's to Cisco IP phones. This means you will not be able to modify text without een screen refresh.
You could send a CiscoIPPhoneText XML object containing some text, wait for a second and then send it again with other text.
Good luck!
marwa_ads Wed, 03/12/2008 - 04:15
Dear Sir;
I used the screen refresh every 1 second, but i need the screen to be refreshed every 500 millisecond , can u help me please in this point.
