About Port Mirroring on C6509
Answered Question
Mar 4th, 2008
I have one question about Port mirroring on C6509 with CatOS.
I wanna mirroring Mulit vlan with port mirroring command.
How do i configure it ?
I means all vlans I have.
I need ur help.
Correct Answer by nordick26 about 9 years 2 months ago
it should be quite straight forward.
Just need this command
set span "Source_VLAN_Number" "Destination_Port_Number"
I you have a range of VLANs, you can use this format:
set span 1-20 1/1
To verify your config, you can use:
show span
command.
Ivan
[please rate any helpful posts]
Overall Rating: 5 (1 ratings)
Correct Answer
nordick26 Tue, 03/04/2008 - 03:43
set span 1-20 1/1
show span
command.
Ivan
