Enable the ports
Mar 4th, 2008
I want enable tcp 14085-15084 and udp 16386-25386 ports in cisco 1841 modular router. Please any one help me about this.
Richard Burts Tue, 03/04/2008 - 04:50
I probably do not understand your question properly. What do you want the router to do about these ports? Do you want the router to process the ports itself? If so for what purpose? Do you want the router to forward these ports? If so the router should forward these ports by default unless you have configured access lists that block them. If there are access lists then you need to tell us what is configured on the router before we can advise you what you need to change.
Can you help us understand better what it is that you are trying to accomplish?
achantamadhu Tue, 03/04/2008 - 06:21
Hi Rick
I want configure tcp 14085-15084 and udp 16386-25386 ports in my cisco 1841 router.
And tcp 5001,1720 and udp 5001,1719 also.
I want nating the privite ip to public ip.
because i want to setup video conference in my orgnization.
Thank you,
