Mandatory Background Image ?
Mar 4th, 2008
Is it possible to push a mandatory background image to the phones and lock the setting ?
CallManager Express 4.1
Cisco Unity Express 3.1.1
Cisco IP Phones 7941GE
Thanks !
espereir Tue, 03/04/2008 - 18:04
Hello Oliver,
Unfortunately this is not possible, unless specified by the user, the phone will use the built-in background which is hard coded on the device load. The only option that I see will be to manually set the new background and then block those settings.
Hope this helps!
nicolas.vallot Mon, 02/09/2009 - 08:58
I have the same question.
Anyone know if it's possible to do this and how ?
Many thanks
