2811 multiple vpn?
Mar 4th, 2008
Hi all
Pls i have a router which has ipsec and isakmp already configured with a ppp link .
My questions is can i do multiple vpn with the 2811 series ?
The model of the router is stated below
Cisco 2811 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ............
6 FastEthernet interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102"
I want to do vpn over the internet .can the 2811 do it ?
Pls i will appreciate your detailed reply .
Richard Burts Tue, 03/04/2008 - 08:50
Perhaps there is some aspect of your question that I do not understand. But the 2811 can certainly do VPN over the Internet (assuming that it has the right feature set to support VPN - which yours does if it is already running IPSec with ppp link.
I have done IPSec VPN over the Internet with 2800 series routers and they work very well for it.
american1 Tue, 03/04/2008 - 08:58
You can have multiple crypto maps configured with associated ISAKMP references. As long as you configure these correctly you shouldn't have a problem.
